HMC150 vs. XH A1...Help!
DV tapes deteriorate faster than digital storage. in fact digital storage does not deteriorate whatsoever
Digital storage does deteriorate, an expample is a hard drive, after time the magnetic code gets weak and will eventially go away completely. Most drive manufactures recommend pulling them off the shelf's once a year and copying them over to another hard drive to restore the strength of the magnetic signals.
That's not totally correct.
Every mfg. has reccomendations, usually listed as MTBF. Thats for an operating, not stored drive. The MTBF is usually listed as 5 years and there is no "pull it out of storage and copy it" reccomendation.
I still have some 20 MB (not GB) drives from the 80s that still work fine and I have never copied the data to refresh it.
There are a lot of data management web-sites that cover this.
Sample HMC150 Frames
Hi,
I came across this forum thread and thought you might want to see some frames from footage I shot this week of a stage performance at full zoom.
Settings: Gamma=CineLike-D, gain=+6, Iris= either open or 4.0, matrix-Norm1, DRS=off, recording format=PH 720p.
The guitarist in two of my frames was standing under a bright stage light.
I wish I had the camera longer, but I was only able to borrow it for a week. I had difficulties brightening the stage behind the performers without overexposing/clipping the performers under the stage lights. The HVX200 I have been using seems to do a better job brightening up the picture without overexposing the bright areas. With the zebra pattern set to 75%, the HMC150 overexposed the highlights while the HVX200 does not.
Mark
So, unless you are going to have that XH-A1 in 10 years, those tapes are worthless. Will new TVs then even have analog component inputs? The XH-A1 dosen't even have a HDMI output.
Hm, I usually dislike versus threads, but here goes.
First of all, who gives a crap about storing your footage on tape? You're going to digitize that and store the raw on a hard drive, just like you do footage from a solid state camera! Unless you plan to store your footage on P2 cards permanently, it's going on a hard drive, and then we're back to square one.
Second of all, who cares about component and HDMI? HD-SDI is the professional standard. My HDTV has both component and HDMI, and the quality is exactly the same. So what's your point?
The next HD standard, UHD, is already in the works. Get rid of that tape/analog output dinosaur XH-A1 and move into the 21st century.
This is just ridiculous. Newer doesn't always means better. I explained a while back in another thread why the HMC would not work for everyone, and you can take a look at it here. Bottom line is that you always need to consider what you need the camera for and whether you can handle the flaws of the camera.
miniDV tapes..
miniDV tapes..
Hi Guys,
I don't know what are you talking about loosing data on miniDV tapes..
I have a series of tapes recorded 10 years ago, and they work like it was shoot yesterday..
On the other hand, I have some fotos on the HDD for three years not moving arround and it is allready impossible to open the,, lost completely..
Cheers,
:beer:
Iris/Gain settings
Iris/Gain settings
Why would you have the gain at +6 but be stopped down to f4?
Good question. First of all, I am not a professional cameraman although I have been recording Sunday morning services for four years now. The reason I use a gain of +6 is because if I don't then the musicians not under the spot lights are dark and grainy. With a gain of +6 I am able to open the Iris for the musicians not under the spotlights and then I am able to close it to f/4 for those in the spot lights and/or the main speaker. I also read that an f-stop value between f/5 and f/8 produces the sharpest pictures (Television Production Handbook 9th Edition). Bottom line, these settings look best to me. I am wide open to suggestions however.
Regards,
Mark
(quote) "I also read that an f-stop value between f/5 and f/8 produces the sharpest pictures (Television Production Handbook 9th Edition)."
Not with small sensor cameras..
Actually, this is true for all cameras. Stopping down a lens always improves sharpness across the board and even though you're getting a cropped FOV the image is still going to be sharper if the lens is stopped down.
Theorically you are right. But with small sensors, and therefore small lenses, diffraction problems come in as soon as you start stopping down.
Even the very good, professional and expensive 35mm lenses loose quality when stopped down to -say- f22. With shorter lenses this happens way before.
Nd filters are there for a reason, not only not to use faster shutter speeds.
I'm not aware that diffraction comes into play that soon for shorter lenses, so I might be wrong. I know that diffraction comes in at around f11 for most lenses but I'm fairly sure that you can still improve image sharpness on smaller camera if you stay around f4-f5.6.
That argument doesn't even make any sense unless your trying to claim the 150 shoots UHD...one thing does not have anything to do with the other.
Diffraction at HD resolution starts to kick in at f/4 for the red wavelength. The smaller the pixels, the more affected the imaging system will be. You can get away with f/8 on an HVX200, but I wouldn't normally run f/8 on an XHA1 or HPX300. Lenses typically perform best around f/4 to f/5.6, yes, but when you're dealing with small highly-dense chips you really have to avoid deeper f-stops. As a normal practice I'd probably say f/5.6 is about the limit you'd ever want to go to on something like an XHA1 or HPX300 or V7U.
Would you please explain your comment in more detail? The HMC150 and HVX200 have 1/3 inch CCDs while more expensive cameras have 2/3 inch CCDs. What is considered a small sensor camera and what f-stop values work best with small sensor cameras verses large sensor cameras?
Thanks,
Mark
