XH A1 uses high definition CCD, while HMC150's CCDS have a resolution of 960x540, using pixel shifting to achieve high def, so it does not look as Sharp as XH A1. Usually pixel shifting visually increase resolution by 50%, so from 960x540 to 1440x810, while HDV is 1440x1080.
If I have $$$, I would buy both, but in any case when I need sharpness, I will use my SONY HDR-HC3
I'm on the verge of purchasing a new camera in the $3,000 range and don't know wether to go with the HMC or the XH A1.
Please give me your opinions and explain why as much as you can.
Big thanks in advance.
Hey, Jeff - you may not care for advice from someone that has neither camera (yet), but I have been going through the same evaluation process trying to determine which to buy. I have been haunting this site and dvinfo.net, reading posts and comments and evaluating (on paper, at least) the XHA1, HVX200, EX1, HPX170 and the HMC150. I am a lifelong Canon shooter and am transitioning into video from a still photo background, so my first inclination was just to be loyal and go with the XHA1.
Since I am not so advanced in the video area, I probably won't be able to eyeball the differences in the video quality between the two and so I tended to throw away this part of the selection criteria, as either will be good enough for my purposes. Next, and really of high importance for me, is getting out of the "mechanical" (e.g., tape-based) recording media and to use SS media. This throws out the XHA1 and the HVX200. Of the remaining cams, I really looked hard at the EX1 and HPX, but for my circumstances spending nearly double the cost of the 150 just on the camera alone doesn't make sense, and the price of the P2 media that would be required is prohibitive. For the EX1, there are some 3rd party solutions for shooting to SDHC that now seem viable to cut costs, but the even higher price of the cam over the HPX doesn't work for me.
So, to make a too-long story shorter, I have settled on the 150 and will be placing my order prior to the rebate offer being withdrawn in March. I like the idea of shooting on the SDHC cards, and at the price that they are now (and getting lower), I am planning on using the cards as archival media and transcoding from there into Cineform intermediate for editing.
I hope this point of view helps you in your decision making.
For those of you that have used both the A1 and HMC150, how does the 150's stock lens compare depth of field wise to the A1's? Yes, I know that a stock lens won't give me as much control as a DOF adapter will. My reason for asking is because the A1 has pretty darn good DOF control for a 1/3 CCD camera, and I will probably only add a DOF adapter to my arsenal if I end up switching to the HMC150 later this year (mainly due to the flip function making it easier).?
The ccd size is the same, it's just down to the aperture of the lens. HMC is 1.6-3.0, maybe you can find out the value for the Canon.
Canon A1 is 1.6-3.4 (f=4.5mm - 90 mm/35mm equivalent to 32.5mm - 650 mm). And the reason I ask is that for getting more DOF control when zoomed in, the A1's lens is 20x while the HMC has a 13x (f=3.9mm to 51mm/35mm equivalent: 28mm to 368mm). I remember my DVX having pretty good DOF for a 10x lens, so I figured maybe the HMC will have good DOF with an even longer zoom to wide range.
If we round both telephoto values up, then the HMC is basically 400mm/35mm equivalent, while the A1 is 650mm/35mm equivalent. I guess that can make a noticeable difference in achieving shallow DOF with a stock lens when on a telephoto setting.
The A1 has a longer zoom so if you use the very top end of that zoom, theoretically you might achieve shallower DoF, personally that is not something I would find practical to do, maybe if you are a bird spotter?
So in realistic terms, they are identical for DoF.
If DoF is important to you I would strongly advise getting an adapter, the HMC has a flip option on the LCD so you don't need a flip device, which is very handy. Also, it is better in low light then the A1, which is also helpful for adapter use.
