Emanuel
Cross-Examiner
Posted three hours ago:
http://forums.dpreview.com/forums/readflat.asp?forum=1032&message=30332040&changemode=1
«Theres been lots of threads about how you can't set the aperture for video on the 5Dmk2. Particularly with regard to using wide apertures in daylight shooting.
One method is to use lenses with aperture rings. eg. nikon lenses via an adaptor.
However theres another way I found which seems to work with AF Canon lenses so long as you choose an aperture and ISO setting which is "within limits" and has a shutter speed of over 1/40th. sec.
1)With the camera NOT in live view - Select Aperture on the mode dial
2)Choose the aperture you want to use.
3)Set the ISO you want to use.
4)Go to menu - choose Live View/Movie func. set
5)Choose LV func. setting
6)Choose Stills+Movie
7)Choose Exposure simulation
8)Press the Live View button
9)Focus
10)Press the AE lock button
11)Press record
This seems to work so long as the shutter speed isn't below 1/40 sec.
I've shot a lot of footage in bright sunlight using lenses wide open f/1.8 f/2.8 etc.
Following these steps the video records in the selected aperture. You can check this by slightly depressing the shutter butter.
Also if you set the on/off switch to the Quick control dial switch you can make +/- adjustments while shooting (It changes the ISO speed)
Hopefully I've not missed anything out. If anybody knows a simpler way that would be useful.»
~ David Martyn
9)Focus
11)Press record
~ David Martyn
