Lee Wilson
On topic, you are right. Different approaches indeed.
Different results often require different approaches.
Wouldn't you suggest the low speed then?
For what ?
In this case, since the video seems to be limited to the 1/30th and 1/125th, what would it be your suggestion?
For what ?
Is a 125th shutter enough?
For motion stabilization, motion tracking, compositing and so on ?
1/125th is not very fast but it helps a little as it removes some of the motion blur.
Or is a higher shutter speed strictly necessary for a good 24fps conversion?
Ok, now you have gone off the rails again ! We were comparing A with B.
A: A filmic look (through the emulation of a specific shutter angle to render a certain amount of motion blur that is common to motion picture cameras with a 180 degree shutter)
. . . . with . . .
B: A very high shutter speed to freeze motion and make post production technique (such as motion stabilization and compositing) easier.
And now we have moved on to the question of is a high shutter speed necessary for a good 24fps conversion !
My answer to this unrelated question would be 'no', not at all, a high shutter speed is not necessary for a good 24fps conversion, I don't believe I have ever said it was.
:crybaby:
