Lee Wilson
so why seems so slow?..
Seems ok to me.
test footage of a baby thats staying pretty still doesn't convince me I can successfully retime the overwhelming majority of my footage.
So, are there any tests showing the 5DM2 retimed (preferably to 24p) in situations where artifacts are likely (many similar items in frame or multiple moving items in different directions, or whatever)?
doesn't retiming affect the footage?.. slowing the motion?
Okay, but what does retiming mean? 25 fps = less 5 frames. Any drop? Nope. What's up?
It's probably too simple for a few. But ask to everybody, I bet 4/5 don't follow what retiming is.
I didn't understand this system of retiming either. Isn't it the same as overcranking?
Thanks for that Lee!
DL'd the footage and it looked quite good except for some horrific artifacts with people moving past each other in multiple directions at about 1 sec in 5D MkII 30p to 25p test 2.
Hypothetically, what would the workflow be?
With which tools?go through and check for any weirdness or artefacts - and clean them up.
With which tools?
Hey Denver,
Does this method avoid adding interpolated frames to the footage? It seem like its the reverse of doing a 30 to 24p conversion with the frame controls turned on and quality set to "high quality motion compensated", and duration set to 100%.
I get pretty good results this way, but you do get interpolated/blended frames that are sometimes noticeable in the footage.
Have you stepped through your footage to see if you get occasional interpolation frames?
Thanks for posting!
