I like the look of the hvx myself, but if it doesen't reslve more reolution then the 200a then an upgrade would be pointless for me and a wait on a higher res camera with the same pana mojo would be a better option for me.
At this point, as I compare the image quality of both my a1 and hvx200a i'm stoked that the a1 delivers such a sharper image without sacrifising the filmic look as do the sony ex1, and at $2000 savings. the hvx200a will be heading back to b&h photo in return for another canon a1.
Dozens of features, lots of really cool features. Things like a built-in waveform monitor and vectorscope, the LCD flip for 35mm adapters, delete-last-clip function, frame rate buttons on the body rather than having to go into the menus, 20 frame rates instead of 11, HD-SDI port, a locking 6-pin firewire port, the ability to input HD through the firewire and display it through the SDI or component output ports, a software keyboard for entering metadata or user clip names right in-camera, finer levels of image control in the master pedestal, two more focus assist functions, a much better/more visible peaking circuit on the LCD panel, a wider lens... all sorts of stuff. Look in the "articles" section for my HPX170 "First Look" and "Second Look" articles.What are some of the features that the 170 will have that the 200a will NOT have, if any?
As far as I know, that is still unanswered. But I can't imagine how they could include a card with the 200A and not include one with the 170, that just wouldn't make any sense, so I definitely expect that it'll have one.On of the unanswered questions about the HPX170 (as far as I know) is whether or not it will include a P2 card.
No. The 200A is the same as the original 200, the only changes are the new chipset and better clarity on the LCD.Thanks Barry, but doesn't the 200A also have these features? Other than the lens and tape deck isn't there other camera features that are different between the two?
You did indeed read that correctly. At least for HD-SDI (and yes, in HD). Don't remember if it could do it in component or not, but I can't imagine why not.Did I read Barry's post correctly?
Did he indicate the 170 will act as a pass through from a NLE to display video from a FW feed out to either SDI or component?
