mikkowilson
Steadi-Guru
Yeah, AVC-Intra supports 1080p recording, so the higher models that have AVC-Intra then also support 1080p recording, as well as shooting.
- Mikko
- Mikko
but, I don't think they are able to get that into a form factor this small yet. Complete speculation on my part.
Later,
Jason
Yes. I believe I heard Jan say something to that effect. It's the hardware that's too big today. They aren't quite there yet. That's why I speculate that the true next generation of the handheld line from Panny may very well include AVC Intra instead of DVCPRO HD.
I could be completely wrong though. Plus, there is cost to consider. AVC Intra being pretty new will cost more, and they have R&D dollars and such to recoupe. DVCPRO HD is pretty old, so there isn't much in the way of added cost that has to be passed along to the consumer.
Later,
Jason
Only if you needed tape still... I heard Barry mention to someone today, that the only other possible reason may be if the 200a has a little better lowlight performance due to the larger glass than the 170, but that is still unknown until someone can put both of them next to each other and test for it.
But, pretty much... if you still need the tape deck, then you might want the 200a. Otherwise, it's the 170 all the way.
Later,
JUason
The menus were not enabled so we don't know. The switchable 50/60hz thing is a raging debate right now.Can someone who is going to NAB check whether the 20 frame rates advertised for the new HVX170 include standard PAL rates (ie 25p and 50i)? One of the big problems for film makers in PAL regions such as EU and Australasia interested in the HVX200 has been how much more expensive the PAL version of the camera is (ie 50% more!). Thanks heaps.
I'm always clamoring to get products as early as possible. The 200A is already available, you can buy one today. For the 170, they said "September."Barry, did you ask if you could get pre-production models of the 200A and 170 later on this year which are about 95% finished so you can do some testing for us ?
Barry, you supposed that the angle of view on the HVX200a in comparision to the HVX200 has changed due to bigger sensors. Can you confirm that? And does the claimed resolution of 1,1 million pixels mean it´s something close to a 720 x 1280 sensor (which would account for 0,92 million pixels)?
