SaintDemure
x
I'm considering Pinnacl Studio Plus version 11 that supports HD , any comments before proceed ?
Hi,
Don't know if this is the right place to post this but can anyone here direct me to a forum where I can ask about problems with the XH-A1? I have noticed speedy playback on footage after shooting at 24f and capturing at 29.97. Any possible reasons for this? I was given to understand that I need not do a pulldown with 24f because it is not real 24p footage. Thanks for any help.
P
I do have a tip that might help you in the future, instead of makeing your vignette black around the edges, there might be a better way to do it. Doing it the way you do it makes it seem like you are almost using binoculars on some shots. Try this.
Pick out the clips you think would look better with the vignette effect. Take the individual clip into after effects. Create an adjustment layer above your footage. and double click the eliptical mask tool to creat an eliptical mask that scales to your footage. Put a curves effect of the adjustment layer and bring down your rbgs to your liking. feather your mask and change it to subtract instead of add. That way your footage will vignette the colors around the edges to darker shades, instead of just black. Ill post an example in a bit.
