Barry_Green
Moderator
Ultimately yes, it's the fault of Apple for insisting on converting away from the native file format when no other editor makes you do that. However, that's completely overcomable on both sides -- on the Apple side you can use Raylight and edit the native MXFs and never run into this again. Or, on the Windows side, now that the damage is done, you can use the Raylight Quicktime Decoder and access the Quicktime DVCPRO-HD files.
So either way Marcus can bail you out.
