tnle2
I think with any solid state based camera you will always have the extra step of off-loading the footage to something else. The advantage of the XDCAM system is that you when you off-load to the professional disc, you already have your archive copy. When you off-load P2 to the P2 store, you still have to archive that data to another hard drive or something else. Also, the professional disc are rewritable and protected inside a case so they're not as fragile as just burning blu-ray disc. And if you acquire in XDCAM-HD, then archive to disc, the format, proxy and metadata all stay the same. So if you look at this objectively, the XDCAM system is actually very slick. It's well integrated and definitely worth a closer look.
