JimmyTheSaint
Carbonite Member
Barry_Green said:Yep, transferring on a PowerBook can cause these glitches. Don't use a PowerBook to transfer whenever possible, use a PC laptop and you'll get flawless transfers.
Do you have some specs for a PC laptop that can be a designated transfer computer?Barry_Green said:Yep, transferring on a PowerBook can cause these glitches. Don't use a PowerBook to transfer whenever possible, use a PC laptop and you'll get flawless transfers.
JimmyTheSaint said:Nah, I run 10.4.8 with 5.0.4 all day long with zero issues.
It happens in all sorts of different ways. We have reports of it glitching in drag 'n' drop, and glitching when importing directly from the cards, and glitching when not even importing the footage at all, just playing it back in P2 Log directly from the card.Ted Spencer said:Is the Powerbook glitch problem specific to a certain kind of transfer or does it happen either way?
Anything would work. The cheapest, slowest $299 blowout special at Circuit City would work; just make sure it has a PCMCIA/CardBus slot on it. Lots of PCs still have it, but some are ExpressCard only, so make sure.ez_dbc said:Do you have some specs for a PC laptop that can be a designated transfer computer?
Just drag 'n' drop the files from the card to an external FAT32-formatted hard disk.Also, I know how to transfer footage to a MAC and import to FCP, but how do you on a PC?
No different. Unplug the hard disk from the PC, plug it into the Mac, and import the footage.And if FCP is the final destination...any tips on this?
So don't use the PC laptop hard drive for footage transfer, only an external FAT-32?Barry_Green said:Anything would work. The cheapest, slowest $299 blowout special at Circuit City would work; just make sure it has a PCMCIA/CardBus slot on it. Lots of PCs still have it, but some are ExpressCard only, so make sure.
JimmyTheSaint said:No on the Norton. In fact the only thing that computer has on it is FCP 5.0.4 and OSX 10.4
You could, but to get it to the Mac you're going to have to use an external drive anyway. In projects that I've done which were destined for the Mac, I always just use an external FAT32 drive. It's effortless, painless, easy, and reliable.ez_dbc said:So don't use the PC laptop hard drive for footage transfer, only an external FAT-32?
TimurCivan said:Well theres your problem!
Its a known issue that macs and p2 have an uneasy truce. Theres like 2 bigthreads on this here and how to minimize problmes.
Lez said:I must admit I've put my camera and PowerBooks through hell the past 7mths.. from shooting in Blizzards to 4x4 driving and micro light shoots.... I've yet to lose any footage... I'm keeping my data base by numbering all the cards as I shoot...I'm up to Disc 183..
I had issues with downloading on a PC laptop but have not lost footage yet.. (touch wood).. I've had powerbooks lose battery power while transferring and to my surprise after replacing the battery the system continued to transfer the material.. no lose of data.. (not sure how the powerbooks manage that as there was no other power to the system but seems to hold a level of charge internally)..
I had P2 cards accendently being ejected as they were downloading while driving along a bumpy tracks, filming and downloading on my lap as we were going.. still no lose of data...
I don't think P2 is impervious to loss.. but in my limited experience it's proved very robust...
Cheers
DavidBeier said:Currently, I've shot countless times with P2 and haven't had any issues. Once, when trying to offload from the camera, I got an error message and freaked out but it was fine once I restarted. Compared to the numerous dropped frames, weird blocks, and other issues I've had from tape, P2 has been a far preferible experience, so much so that I opt to do all my jobs with P2 when possible because of the easier workflow.
DavidBeier said:I've seen you esposing the virtues of the FS-100 when other people have had issues with it. It all comes down to our own experiences and mine have been overwhelmingly posative.
Of course, if my cards fail me I'm sure all be full of riteous indignation if not pure rage.
ozduc said:I thought the last compatible OS with FCP v 5.0.4 was OS 10.3.9.
