iain.bason
PaPa said:dvx does an uprez? huh?
In squeeze mode it is effectively uprezing (though not to HD, of course).
InvisionProductions said:Yeah, I just dont know...technically, it should enhance the footage...Its not like Photozoom's algorithm says "Your final product can only look this good." I believe that Photozoom's uprez back to 16:9 would yeild a much higher quality result...Technically, I am gaining more resolution just by shrinking the 16:9 file down to 4:3 letterbox, add the photozoom process on top of that, shouldnt it make a pretty significant difference?
InvisionProductions said:1) Capture XL2 footage as 16:9 widescreen footage
2)open a new 4:3 project and import those newly captured 16:9 files. "shrink" the video to fit a 4:3 monitor (should give you the whole widescreen space, with letterboxing)...
...but this should yield even higher quality results than that of the DVX, simply because you are starting out with more pixels crammed into that 4:3 file with the XL2 than you are with the DVX!
InvisionProductions said:Isnt it logical that to take stock 16:9 footage, resize to 4:3, uprez using Photozooms s-spline back to 16:9, the new image would look better and higher res than that original 16:9 footage? If not, than this process is pretty much pointless. I just need to know, YES OR NO!
The quick answer would be "No."InvisionProductions said:Isnt it logical that to take stock 16:9 footage, resize to 4:3, uprez using Photozooms s-spline back to 16:9, the new image would look better and higher res than that original 16:9 footage? If not, than this process is pretty much pointless. I just need to know, YES OR NO!
That's an oxymoron right there. Downsizing will only improve perceived quality. If you take an 640x480 picture and downsize it to 320x240, you're obviously removing pixels (i.e decreasing resolution, thus less quality). But the 320x240 picture may *look* better because it's smaller, which allows it to hide some of the flaws of the bigger picture. This is perceived quality.InvisionProductions said:...downsizing it to 4:3 letterbox should increase the quality...
