BrianMurphy
Thanks to everyonewho linked me up with the specs a while back. I finally bought a six pack and sat down with the soldering iron. Here is what it looks like.
Cost:
Box-2.50
Contact switch -1.49
2-20K linear mini pots- 4.99 each =9.98
1-30K linear pot-2.99
2-female 3.5mm stereo jacks .79 pk of 2
1-2.5 male stereo jack-.79 pk of 2
1-3.5 male stereo jack-.79 pk of 2
Knobs-1.50
wire I had on hand.
Total:about 20 bucks
It works like a charm,though I am going to try a couple more pots on the zoom, the iris and focus work fine with 20k, just would like a bit more gradual control on the zoom which could also be because the pot is so cheap.
I will use a bicycle bracket to attach it to the tripod arm and probably epoxy the screw to the bracket and use wing nuts to make it easy to take off.
It is an easy build, the biggest problem is finding a box that is small enough and then getting jacks that will go through the walls of the box. I had to hot glue my jacks in place from the inside because they were too short.
Cost:
Box-2.50
Knobs-1.50
wire I had on hand.
