I was frustrated by how jumpy the Zoom rocker is for the sony 18-110 when using on event presentations where you need to be live all the time, and finally called my friend Charlie Pickel at Serious Gear Company in Seattle. He's a broker for used cinema equipment and lenses and he set me up with an old film style J4 motor and Microforce controller that i can run off a D-Tap.
Wow what a difference! I can do smooth as butter moves now. Its an absolute pleasure to operate.
The set up is a little tricky because you need to add a standard 0.8 32 pitch gear to the zoom ring on the 18-110. I had an adjustable one from "shoot 35" that just fit the lens, but when I first tried mounting the motor to my 15mm rails with the adapter Charlie gave me, the motor was so long that it hit the camera body and couldn't get close enough to the lens to engage. (The more commonly used and somewhat more expensive "Heden " motors are supposed to be smaller but I don't know if they'd fit better.) So I turned the motor around, having the long end stick out in front of the lens. This just managed to engaged the zoom and just barely avoided being seen at 18mm but it was in the way of any kind of matte box or the standard lens shade. Nevertheless it was a proof of concept and works great.
Sean at Follow Focus Gears is now about to borrow a friends 18-110 lens to make up an extra wide gear (OD 120mm) so that it will allow me to turn the motor back towards the camera again but engage the gear. Once he does that he can just knock it out on a 3D printer for less than $50. I'll post pics when I finally get the rig properly set up.
I highly recommend this if you want a zoom controller that to me is even better than a traditional B4 2/3" Fuji type. Most of the parts I think these days are used so you need to hunt around yourself or go to someone like Charlie. I recommend the latter as he was able to fine tune my J4 motor and give me all the proper gear to power safely from a DTap . Because its all used gear also the price will vary with availability of parts. Generally it should cost in the $1500-$2000 range. Not cheap and frankly I don't know if I can convince clients to pay for it but it makes a world of difference to what they'll be getting.
http://www.seriousgear.com
https://followfocusgears.com
Lenny
Lenny
