S
steadicamsteel
Guest
Hi Folks,
Just received my custom made Focus Gear Rings for Jerry at JBK Cinequip in Hollywood, Florida and had to share this with you all.
Firstly, Jerry makes custom sizes for different lenses, you just have to send him the diameter of the lens you want the Focus Gear to fit and he'll make it for you. No massive gaps around the lens gear like some systems and hassle free fitting (like a glove). No slipping or movement once you mounted the rings. Bloody Excellent.
Secondly, no screw mounts or blocks to get in your way (impede) when pulling those long focuses. So no hard stops when you run out of teeth on the focus gear. Complete 360º+ movement and your teeth are still engaged with your Follow Focus Unit or motor all the way, and some.
Thirdly, they're manufactured out of alloy so no replacing those worn plastic zips after a few months of usage, which they do (from personal experience).
Forth and MOST IMPORTANT OF ALL. They are extremely cost effective. $79 (US) per CUSTOM Focus Gear Ring and remember they're fit for purpose and designed for the actual lens your wanting it to work with.
So all in all Superior in every way to the Zacuto Zip Gears, Redrock Lens Gears and pretty much every other Lens Gear I've come across and used to date.
Custom sizes are made to order and have a 2 week turn around.
I have no ties with JBK Cinequip in any way shape or form but felt I needed to highlight the excellence this small independent company has achieved in delivering a component part which is fit for purpose and not some half hearted work around that other manufacturers seem to think will do.
Excellent communication, the man (Jerry) is a Legend.
http://www.jbkcinequipt.com/PRODUCTS.htm
