YWAIN Rig V2: Handheldness
Kholi
Section Moderator
Here's V2 of my "rig". It's a bastardized something, created from Redrock and Zacuto parts. You could probably replicate this all RR or all Zacuto which is great for purest.
Stats:
18 inches from rail end to end
Weighing in somewhere around 14 to 16lbs
Balanced to the shoulder, no see-saw effect
can be extended slightly for Mattebox Application
Tail end shows the Zacuto Shoulder Pad beneath the Zacuto Lunchbox which is flipped upside down. The Zacuto Z-Riser is also playing a major role in allowing two sets of rods to be employed AND both the Shoulder Pad and Lunchbox in the same space.
This is awesome. And by awesome I mean totally sweet.
At the front you can see the Zacuto Arms, Redrock Handles, Redrock DSLR V2 Bracket (totally awesome quick release system, genius), Zacuto FF, Redrock Whip and ye ole 5D Mark II.
Because the handles drop so low there's a reduction in fatigue. I don't have to reach way up to do anything on the camera aside from hit record, and if I have my way I'll have a trigger mounted to the right handle soon enough.
Also, the Follow Focus whip hangs down near the left handle, reducing the travel distance between the handle and whip knob for focus pulling.
The Redrock handles serve a great purpose as well. Being so tall, I have a tendency to cradle the camera. The Redrock Handles allow me to grip the unit at the left and right side while the Zacuto pad drops onto my forearm. This way I can shoot at chest height comfortably and steady. Reaching forward to pull focus is of no consequence, works quite well.
Sweet.
And the top of the system. Gone are the days of super long rigs. This puppy is acceptably compact for my purposes and because of the weight, a necessary evil, I'm quite comfy operating manually, without IS lenses or stabilizers, up to 300mm.
As a handheld freak this is great, since most of the time I'd be on 180mm max during a standard shoot. It's a breeze. No more of those pesky tiny shakes that look like I'm spazzing behing camera beyond 50mm.
This is just V2, though. There are quite a number of updates I'm getting together, including the monitoring solution.
Parts list:
1) Redrock FF Whip
2) Redrock Handles
3) Zacuto Rods (Screw Type) up to 18"
4) Zacuto Rods (short set for Weight)
5) Zacuto Z-Riser
6) Zacuto Arms (forgot the name for the long ones)
7) Zacuto Lunchbox (this thing smells really funny. Seriously)
8) Zacuto Follow Focus
9) Redrock DSLR 2.0 Camera Mount (Quick release, stealthy, small, bad ass)
If ya have any questions feel free to post! Forgive the images, taken with my iPhone.
That's a sweet rig you got there. Does it have a quick release system so you can attach the entire rig to a tripod head or do you have to detach the camera itself from the rig and mount it to the tripod head?
=D
I figured that out too. Was gonna post it up with a picture of it all on the crane. But basically, slide the Zacuto shoulder pad off and slide on the Zacuto Baseplate. Fasten 'er down and you're ready to go tripod with the same great weight for smooth panning and tilting.
So thanks to the RR quick release (which is a genius design, honestly) the camera can be detached from everything or just slide on a baseplate and use it as is.
Of course I wish it all looked a bit more streamlined but the closest thing that comes to this setup is the Redrock eyeSpy setup.
I'm working on designing my own bastardized rig in my head. Thinking of going with some Cinevate parts. I especially like their Durus Follow Focus and Titan swing-away matte box for when I'm doing real cinema style work. And it looks to me like they may have the nicest shoulder pad. Would probably go with different grips/handles, bottom plate, and rails though. I'd like to put together something that will work well with DSLR and Scarlet setups so I only have to do it once.
No matter which way you go, make sure you add weight! That's the major flaw in everything I see and everything I've tried. Just couldn't bring myself to see the truth but weight is definitely a must.
The rest is just figuring out what fits your shooting style.
One of the reasons I want the Cinevate shoulder pad. It has 15mm rail connectors on the back. Add some short rails with weight attached to them. Then you don't need as much weight since it's further from camera than putting the weight directly on top of your shoulder. Should be a better balance on the shoulder.
sick set up. love the mismatched parts.
i like the idea of using both the Zacuto & Redrock handles for
the 2 different shooting styles within the same configuration.
one thing i need to do is balance out my rig for shoulder mount work.
i use a gunstock type of deal right now, which works great for about
an hour, then i start to get the front heavy feeling. i shot 90% of my
Clearview Fishing thing in shoulder mount mode.
