Joshua Milligan
So I have a decent budget set aside for a zoom lens for my FS7 MK II. I already own a bunch of GM lenses in the 16-35 2.8, 24-70 2.8, 70-200 2.8, 100-400 4.5-5.6 as well as a Zeiss Batis 25 f/2 and a Zeiss Planar 50 1.4. Those lenses are great on my mirrorless cameras and they are ok on my FS7, but what I need now is one (or two) really good manual zoom lenses that produce a great image and that cover a decent range. I'm tired of using fly-by-wire lenses on my FS7 and I'm wanting to have a servo zoom. My intent is to use this lens (or lenses) for doc work, short films, events, commercials, corporate work and reality television (we do a variety of projects).
Here are the options I'm considering:
1) The Fujinon MK 18-55 & 50-135 set at $7,800
These are obviously beautiful lenses that are fast, fully manual and lightweight. Together they also cover a huge range. But, they require an aftermarket servo kit to have a power zoom and aftermarket servos like the Chrosziel Compact Zoom Control Kit have been known to short out the lanc port on the FS7 as well as the motor on the Chrosziel itself. The aftermarket servos also bring the cost of this set up much higher and they require you to use the FS7's handgrip which I'm not crazy about.
2) The Fujinon XK 20-120 Cabrio with the servo drive for $13,500
This is another beautiful lens that has a fantastic range that requires less lens changes, comes with an awesome servo grip that's very responsive, and the entire lens setup works equally well in both an ENG environment as well as in a more tradition film environment. The downsides are the price, the weight, the T/stop at 3.5, and the fact that I'm not entirely sure how well it works together with the FS7 (as in how ridiculous is it going to be to get power to the grip?). I also think that this lens will need a lens support even with the FS7II's stronger mount. My #1 concern with this lens though is definitely the weight and how it rigs up with the FS7. I don't want something that's a nightmare to use.
3) The Canon 18-80 & 70-200 Cine Servo Zooms for $9,600
These lenses are incredible to work with on the FS7II. You don't need a lens support to use them, they produce nice, warm images, together they cover the biggest range I'm considering, they have image stabilization, and they (currently) come with awesome servo grips that are very responsive & very fast, getting their power from the lens mount. Ergonomically speaking, these lenses are amazing to work with. The downsides are that they are slower at T4.4 and not all of their buttons work when adapted to the FS7.
4) The Sony 18-110 for $3,500
This lens makes sense with the FS7 (especially the MK II) because it's lightweight, cheap, covers a massive range, has image stabilization, has native autofocus, and it works quite seamlessly with the FS7, even providing in-camera corrections while still being almost fully manual. The downsides are that it's electronically parfocal, you have to use the FS7's handgrip instead of a lens handgrip like the Canon lenses have or the Fujinon Cabrio (which is not as comfortable to me) and it's slower at an f/4. Also, the servo is kind of a joke as it's slow and laggy.
5) The Fujinon MK 18-55 & 50-135 set with the Sony 18-110 at $11,300
This three lens combo gets you a pair of true, fast cine zooms as well as a run & gun ENG lens. With this set you could use the Sony for the run & gun work and the Fujinons for everything else. The downsides are the cost puts you not that far away from the Cabrio, you have to carry three lenses and the Fujinons would still need the aftermarket zoom motors when wanting to zoom electronically for certain shoots, like docs. You also have to use the FS7's handgrip for everything as none of these lenses have available grips.
I've worked with several of these lenses on my FS7II (expect for the Cabrio), but I cannot figure out the best route to go. If you were looking to go down one of these paths, which would you pick and why?
