PV mount or PL?
I see 2 of them. One is darker :happy:
It looks good man. Did you find that on Ebay? Besides the obvious mount difference, how does this compare to the F35? Is it true that it does not do 12bit? Congratulations!!! Dont destroy your front plate. Try to do a mod that you could reverse it back when you came across some Pana glass.....from wherever it is you found a panavision camera...
....drooling here :2vrolijk_08:
I don't want to sound negative, but the PV mount flange focal depth is 57.15mm. The ARRI PL mount is 44mm. Modifying the camera to accept PL mount glass may prove difficult.
Good, but what’s you plan for optics?
This is from back in the day when there were just a couple of cinema lens manufacturers but three different standard 35mm cine mounts - PV, PL (or even older ARRI Bayo) and BNCR. A few companies making zooms - notably Angenieux - put a universal back on their lenses so that different mounts could be attached. This design only works for a relatively few lenses, usually big zooms or converted telephotos. Decidedly not for primes.
I'm afraid it won't be as easy as you might hope. My suggestion is to give Matt Duclos a call on Monday and see what he might suggest. Perhaps he knows an inexpensive option.
