Yeah I still have mine and am currently working a new suit for the F35. Something considerably lighter and smaller... If I succeed I will show you.
Fascinating!
Can't wait to see what you come up with for a case!
Maybe make a thread for your build?
Sorry to hi-jack the thread, I will start a new thread shortly, I promise this isn't vaporware, I have crossed the point of no return so I either make it work or I crash and burn hahaha.
I removed about 500grs of boards on mine that I wasn't using (ethernet, 2nd EVF, zoom contorller, top ports) but in the end if didnt' make much of a difference really.
Grug, I know you love 12bit on the F35... Did you ever do some 10 vs 12bit tests? I would love to see them if you have any. I am still trying to find significant differences between the two.
Mac yes by removing all those parts I realized there is a huge amount of empty space inside the F35 now, I am removing closer to 5lbs from my camera. I am hoping for something the size of a mini but a little bit longer. I know this sounds complicated, it's along the lines of building a custom computer case. Like I said, the real advancement has been Carbon Fiber pre-made parts, there are square tubes, right angles, square corners and strong panels all fairly cheap. I have help also in the form of an aeronautical engineer who has a background building custom cases for testers at IBM, I am simply standing on the shoulders of giants to make this forgotten camera a modern contender.
I wish I could speed up the mail, there are so many Carbon Fiber parts made for DIY RC Drone projects I am finding everything I need. Also CF can be sanded so I can make the outside layer pretty slick.
The "motherboard" is the "fat" side of the F35, I had a huge break through figuring out I could lower it, once you can lower than board the camera becomes a lot smaller.
Imagine you could cut the front plate right above the bottom viewfinder port and right below the top viewfinder port, this is how my camera will look. The PL will not be centered, one side of the F35 will always be fatter than the other.
Check out these photos: The power supply used to sit at the bottom of the camera, by flipping it on it's side and moving it to the back of the camera, it is a lot more space efficient. This is all the parts needed to run F35.
Grug congratulations you convinced me, I can fit the dock board inside the camera so I'm going to do it. So now I will have 4 SDI ports on the back of the camera, 2 for Monitor and 2 for A and B.
I really will start a new post now. First part is to make new skeleton to hold these parts together. Next is redesigning the airflow. Then then outter case should be fairly easy. The airflow is actually easy because Sony used standard 12v pc fans, I am getting bigger quieter fans and also I can have airflow from the top which Sony couldn't do on F35 because of the top dock.
View attachment 131650View attachment 131650
