xH-G1 makes clunking sound when shaken.
badong
Hello, I bought a used Canon xh-g1 that is still under extended warranty.The camera is working perfectly but when I shake it up and down, it would make a clunking sound. I try with battery and without battery- same result, checked lens hood- ok. Is this normal? Thank you.
I'm almost positive it is. The XH A1 that I use does it, and so do most other cameras that I've used that have OIS when the camera is turned off.
