Would this Mac be enough ?
dLAND
[FONT='Georgia','serif']Hello Peers,[/FONT]
[FONT='Georgia','serif'][/FONT]
[FONT='Georgia','serif']I want to edit with Final Cut 6 (and if possible with Edius and SpeedEdit), teh native 720/25PN MXF files of the HVX 200, coul you advice me if this machine will allow me?[/FONT]
[FONT='Georgia','serif']Any advice will be welcomed.[/FONT]
[FONT='Georgia','serif']Thanks a lot. [/FONT]
[FONT='Arial','sans-serif'][/FONT]
[FONT='Arial','sans-serif']MacBook 2.0GHz Intel Core 2 Duo[/FONT]
[FONT='Arial','sans-serif']13.3-inch glossy widescreen display
1280 x 800 resolution
1GB memory (2x512MB SODIMMs)
80GB 5400-rpm Serial ATA hard drive
SuperDrive (DVD±RW/CD-RW)
Built-in iSight camera
[/FONT]
[FONT='Arial','sans-serif']Model[/FONT]​
[FONT='Arial','sans-serif']MacBook - White[/FONT]​
[FONT='Arial','sans-serif']Processor[/FONT]​
[FONT='Arial','sans-serif']2.0GHz Intel Core 2 Duo[/FONT]​
[FONT='Arial','sans-serif']L2 Cache[/FONT]​
[FONT='Arial','sans-serif']4MB shared[/FONT]​
[FONT='Arial','sans-serif']System bus[/FONT]​
[FONT='Arial','sans-serif']667MHz[/FONT]​
[FONT='Arial','sans-serif']Memory[/FONT]​
[FONT='Arial','sans-serif']1GB (2x512MB) of 667MHz DDR2 SDRAM (PC2-5300); supports up to 2GB[/FONT]​
[FONT='Arial','sans-serif']Hard drive[/FONT]​
[FONT='Arial','sans-serif']80GB Serial ATA; 5400-rpm[/FONT]​
[FONT='Arial','sans-serif']Slot-loading optical drive[/FONT]​
[FONT='Arial','sans-serif']6x SuperDrive (DVD+R DL/DVD±RW/CD-RW)[/FONT]​
[FONT='Arial','sans-serif']Graphics[/FONT]​
[FONT='Arial','sans-serif']Intel GMA 950 graphics processor with 64MB of DDR2 SDRAM shared with main memory[/FONT]​
[FONT='Arial','sans-serif']Video[/FONT]​
[FONT='Arial','sans-serif']Built-in iSight camera; mini-DVI output port with support for DVI, VGA, S-video, and composite video (requires adapters, sold separately)[/FONT]​
[FONT='Arial','sans-serif']Display[/FONT]​
[FONT='Arial','sans-serif']13.3-inch (diagonal) glossy TFT widescreen display, 1280 x 800 resolution[/FONT]​
[FONT='Arial','sans-serif']FireWire[/FONT]​
[FONT='Arial','sans-serif']One FireWire 400 port (8 watts)[/FONT]​
[FONT='Arial','sans-serif']USB[/FONT]​
[FONT='Arial','sans-serif']Two USB 2.0 ports (up to 480 Mbps)[/FONT]​
[FONT='Arial','sans-serif']Audio[/FONT]​
[FONT='Arial','sans-serif']Built-in stereo speakers, built-in omnidirectional microphone, combined optical digital audio input/audio line in, combined optical digital audio output/headphone out[/FONT]​
[FONT='Arial','sans-serif']Networking[/FONT]​
[FONT='Arial','sans-serif']Built-in 10/100/1000BASE-T (Gigabit)[/FONT]​
[FONT='Arial','sans-serif']Wireless[/FONT]​
[FONT='Arial','sans-serif']Built-in 54-Mbps AirPort Extreme Wi-Fi (802.11g); built-in Bluetooth 2.0+EDR (Enhanced Data Rate) module[/FONT]​
[FONT='Arial','sans-serif']Hardware accessories[/FONT]​
[FONT='Arial','sans-serif']Apple Remote, 60W MagSafe Power Adapter, AC wall plug, power cord, lithium-polymer battery[/FONT]​
[FONT='Arial','sans-serif']Height[/FONT]​
[FONT='Arial','sans-serif']1.08 inches (2.75 cm)[/FONT]​
[FONT='Arial','sans-serif']Width[/FONT]​
[FONT='Arial','sans-serif']12.78 inches (32.5 cm)[/FONT]​
[FONT='Arial','sans-serif']Depth[/FONT]​
[FONT='Arial','sans-serif']8.92 inches (22.7 cm)[/FONT]​
[FONT='Arial','sans-serif']Weight[/FONT]​
[FONT='Arial','sans-serif']5.2 pounds (2.36 kg)[/FONT]​
MacBook - White
Processor 2.0GHz Intel Core 2 Duo
L2 Cache 4MB shared System bus 667MHz
Memory 1GB (2x512MB) of 667MHz DDR2 SDRAM (PC2-5300); supports up to 2GB Hard drive 80GB Serial ATA; 5400-rpm Slot-loading
optical drive 6x SuperDrive (DVD+R DL/DVD±RW/CD-RW)
Graphics Intel GMA 950 graphics processor with 64MB of DDR2 SDRAM shared with main memory Video Built-in iSight camera; mini-DVI output port with support for DVI, VGA, S-video, and composite video (requires adapters, sold separately) Display 13.3-inch (diagonal) glossy TFT widescreen display, 1280 x 800 resolution
FireWire One FireWire 400 port (8 watts) USB Two USB 2.0 ports (up to 480 Mbps)
Audio Built-in stereo speakers, built-in omnidirectional microphone, combined optical digital audio input/audio line in, combined optical digital audio output/headphone out
Networking Built-in 10/100/1000BASE-T (Gigabit) Wireless Built-in 54-Mbps AirPort Extreme Wi-Fi (802.11g); built-in Bluetooth 2.0+EDR (Enhanced Data Rate) module Hardware accessories Apple Remote, 60W MagSafe Power Adapter, AC wall plug, power cord, lithium-polymer battery Height
1.08 inches (2.75 cm) Width 12.78 inches (32.5 cm) Depth 8.92 inches (22.7 cm) Weight 5.2 pounds (2.36 kg)
Basically, no. MacBook Pro would really be the minimum. You can run FCP on a MacBook. You cannot run Motion or Color. You don't have an Express34 slot. Mac users know what a MacBook is so no need to copy the specs from the Apple site.
Ned Soltz
Not a good idea.
I was able to capture to a MacBook, but its limitations are significant.
As Ned points out, a MBPro is the minimum.
I have a black macbook and it runs fcp 5 fine but like they said, its limited in the motion graphics area. I also run after effects 7 on it. With some tweeking of the settings, its not bad. But if your using fcp 6, I would recommend macbook pro to utilize motion and color.
