workflow: HVX+DVX.
Derek_Sine
I plan on getting the HVX for the variable frame rate possibilities, I am currently using the DVX 100a. Would the hvx and dvx flow together, solid similar images?
thanks.
Derek
The thing is, you will need to shoot the variable frame rates in HD, then down-convert them to DV to match the look of the DVX.. I'm guessing with a little tweaking you'll be fine.. But I'm pretty sure the images will look a bit crisper from the HVX..
