C100: Wireless HDMI to external recorder.
sebben
Has any one made any experiments with sending the HDMI signal to an external recorder?
I would like to reduce bulk by not attaching an external recorder to the C100.
I am thinking of using an Ayrius Aries Pro (Pretty much identical to Paralinx Arrow) and sending the signal to a Pix 220i, Odyssey 7 or Atmos Samurai 2.
http://www.amazon.com/Nyrius-Wirele...d=1375533918&sr=1-1&keywords=nyrius+aries+pro
This way the monitor could also double as a wireless directors monitor + I get a better codec to grade.
Any thoughts?
I borrowed a similar one to that one time and it was OK at best for a second monitor, absolutely useless for recording. The second review on Amazon goes into a lot of the reasons why (lossy, compression artifacts, etc.)
Even much higher priced units like these switronic's http://www.switronix.com/products?page=shop.browse&category_id=49 really only promise they are good for monitoring.
I do think there are some that would work for recording, I recall seeing several booths at NAB with this sort of solution, but again they were much pricier than the unit you mentioned.
Any thoughts?
You should never consider "wireless" feed to a recorder if you are working on something that you want to use for editing. I would only consider it good enough for monitoring and video assist. You are going to pay the same or more for a reliable system and even the best have problems at times (and you never know when). I have rented the best systems out there and they work until they don't. Just accept that you bought a C100 and you are going to have to rig the recorder and live with it. Even then I would always record backup in camera on the SD cards.
If you just want wireless for a directors feed then the Paralinx is the best value in a quality HDMI recorder. Don't take a chance on important footage.
