Will this anamorphic adapter work for the 7d?
Yes, it will Craven, but you have to zoom in a bit to account for the larger 77mm filter diameter. Same thing for all lenses with larger filter diameters than 72mm. For VDSLRs though, you'll be limited in a way as, for instance, the new Nikon 24mm 1.4 with 77mm diameter won't work as you are stuck at too wide of a focal length so you would need to switch over to the smaller 52mm diameter Nikon 24mm 2.0 if you wanted a 24mm anamorphic.
what happens if i use a 72mm to 77mm step down ring? which is the ex1 lense mount 77mm...
the guy who did the videos in the above link used it...
