C100: WideDR setting without >100 IRE
Policar
Carbonite Member
Is it possible to make a setting identical to WideDR except that the the knee is compressed to 100IRE rather than 109IRE (making the image I guess a little flatter but losing a bit of precious tonality)?
Clients don't "get" superwhites and it's frustrating not seeing them in the monitor.
When I shoot myself I use WideDR or occasionally Canon Log.
Hi Policar
If you set "Black->Master Pedestal" to about "+4" and "Other Functions->Setup Level" to about "-18", would that be what you're looking for?
I'm not using WDR myself a lot, but the image with the above modification doesn't look so terribly off at a first glance...
Greetings, Roli
Knee has no effect on the cine1&2, wdr and log gamma curves, read this in manual.
You can modify all gamma curves in quick CP menu (gamma curve and WB) or you can set on the clipping (of 100pct Y level at output), but this function also means a less DR.
