It seems like there's some decent options in the m4/3 format, only most of them are too video-y to my eye for some reason, instead of smooth and 'cinematic' looking. The "noktor" 12/1.6 looks great but as with the 25mm Nokton has a little too much DOF for my taste so it's quite "dream like" wide open.
I currently have a set of Pentax smc primes:
28mm/3.5, 50mm/1.4, 55mm/1.8, 105mm/2.8.
The 28 can be used for Wides, and is sharp, but sometimes I want even wider than a 56mm equiv. on a full frame... I also need something closer to a 50mm equivalent, with a larger aperture.
With that in mind, I was looking at some used 20mm m43 lenses that were available. Some older, slower m42 mount ones can be had under $200. I am concerned about their wide-open sharpness - If possible I would like to use them to create DOF for close subjects. Occasional f/2.8's show up but I once again have to question their wide-open sharpness - is it fuzzy, grainy,etc. overall, I am still only achieving 40mm due to the gh2's crop sensor. That's Okay.. it is acceptable. But I also have to bring up the subject of Wide-angle adapters: are there any that work effectively? A 0.65x filter thread adapter would turn my 28mm into about 36mm on a FF - and my 55mm into a 71mm f/1.8 FF effective full frame length. Not bad, if there are any adapters that actually work. Most of the demonstrations I've seen have been awful, with no overall image sharpness (Needed for wide, establishing photography). I have, however, seen some mildly better demonstrations, so I haven't ruled them out completely. A 0.5x adapter would suit my needs just as well, but not necessary if it has alot more image degradation than the 0.65x.
So.. Overall I suppose I'm just trying to get a decent cinematic looking Wide angle, and 50mm. The 12mm Noktor once again appeals to me but I'm really not sure how well it will cut with the Pentax primes, which tend to have a very subdued subtle "smoothness" (even when stopped down). Another huge plus is the ability to use ETC mode make an effective 24mm (or 30mm?) - With a fast 1.6 aperture. I owned the Panasonic 20mm f/1.7 from the beginning and loved it's low light performance and DOF. However it was SO sharp, that it looked like almost a different camera when shown against clips from my Pentax primes. So I sold it.
