Julienmassie
I have heard rumors on the photo side of a m4/3 12-60mm or possibly 12-75mm with a reasonably fast aperture sometime early next year from either Panasonic or Olympus.
That would solve the problem
I use my 11-16mm all the time, but the problem I see with it in tight spaces is that if you don't have the camera locked down, the perspective distortion (not sure what to call it) that you get looks so unnatural and can subtract from the shot if you don't want that to be the focus. Look at the South video by Bloom, when he pans the camera on top of the building, you get that push pull effect as things come in and out of the center of the FoV. At 11mm I definitely get this, and for visual effects work it is a NIGHTMARE. I have to lock almost every shot down as the perspective changes make certain compositions a nightmare.
I've often felt that this is why you don't see super wide often on cinema shots, or if you do, the subject matter is very far from the camera UNLESS you are going for that distorted look (ie Gilliam's Fear and Loathing).
Granted, not all use is for narrative, and with that, I think there is a distinct difference in need that people need to consider. For people shooting documentaries or other sorts of projects, where there is no set, or ability to change the environment (like a cave or something), then these desires have real considerable application. A lot of advice or example tends to focus on one aspect of 'filming' when in reality, there are many applications.
Canon 7D.
I've owned and used a nikon mount 11-16 on a gh1. Also have owned and used 11-16 on canon as well. What do you want to know?
I assume the 11-16 had worse barrel distortion on the Canon than the GH1 due to the extra crop factor with m4/3s.
Here is the answer to our requests:
http://www.bhphotovideo.com/c/product/736393-REG/Panasonic_H_H014_Lumix_G_14mm_F2_5.html#features
Fast and small and will work with AF100.
I think it is rather humorous that over the last while everyone has been clamoring for telephoto shallow focus solutions for video cameras, and as soon as someone builds one, everyone starts complaining about lack of wide angle. Compared to what? Yes there are super wide lenses for full frame stills for shooting big group interiors, but guess what we are movie shooters and can move the frame to take in the shot.
I think the real bennefits of wide angle lens are the near far relationships they create and the resulting visual dynamics. Moving your camera back to see more reduces those bennefits. There certainly are times when you simply need to get a wider view, but I generally am using a wide angle lens because of how it allows me to compose an image, not simply because it allows me to see more.
But how wide do you think you'll need to go? 7mm (from the 7-14) on an AF100 is as wide as 13mm on a "full frame" camera. Neither Canon, nor Nikon, nor Zeiss, nor Leica, make a wider-than-13mm lens on a full frame camera (that isn't a fisheye). Are you saying you need to go wider than the widest of the widest wide lenses that there are in existence? If you want the widest field of view, you want an AF100 with the 7-14.So in this case i really need to think about the crop factor.
