Barry_Green
Moderator
if you want ultra wide, stick with a 5d moire II.
LOL! Post of the decade. :thumbsup:
Hah! You are exactly correct!I think it is rather humorous that over the last while everyone has been clamoring for telephoto shallow focus solutions for video cameras, and as soon as someone builds one, everyone starts complaining about lack of wide angle.
Extremely wide on cinema cameras isn't all that common. Especially in a zoom. Look at cinema zooms, the LWZ 14-45 and the Angenieux 15-40 are about as wide as you get. And those are $50,000 lenses.Compared to what? Yes there are super wide lenses for full frame stills for shooting big group interiors, but guess what we are movie shooters and can move the frame to take in the shot.
Correct. That's wider than the EX1, it's wider than the HVX200, it's wider than the DVX100, it's even a hair wider than the HPX170, which has about the widest standard angle of any fixed-lens camcorder on the market.All of the standard zooms in m4/3 start at 14mm which is already wider than any video camera you've ever used.
Correct. The 7mm is mega-wide. I have an 8mm Peleng which is astonishingly wide, and it's super-barrel distortion. The 7mm Panasonic (the 7-14 lens) is nearly rectilinear, and even wider, than that 8mm Peleng!Add the 7-14mm and it will blow your socks off.
Yes f4 is slow. But you know what? At 7mm, you're getting a wider field of view than a 14mm lens on the 5D Mark II. And if you want a 14mm lens on the 5D Mark II, it's not going to be any faster than f/2.8, is it? So yeah, you'll have to go with 200 ISO on the AF100 instead of 100 ISO on the 5D, but you'll get the same sensitivity and a wider field of view.Yes at f4 it is a bit slow, but consider the pains we have gone through to shoot hv20 with no gain, f2 at maybe 100asa, that would be f4 at 400, if the cam is clean at 800 - 1600 it is a non issue, if so turn a light on.
Agreed. 16mm normally maxes out at about 10mm wide. That's all we've ever really used, folks. And it's enough.On my 16mm kit the widest lens I have is 10mm and I've never had trouble getting a shot, that should have a FOV similar to the 20mm pancake, which at f1.7 should be more that fast enough to cover the dance at a wedding reception.
If You've ever read American Cinematographer Magazine, you'll see that most every shot in every movie you see is 25mm or longer. 18mm is typically the widest standard lens. The prime kits do go down to 12mm but lenses that wide are a speciality item. 10mm on a movie really stands out, there are only a handful of shots in Hollywood history that have used it, and if you saw it, you knew it.
It would be a very common focal length. It's wider than a 25mm lens on a 35mm cinema camera. It's moderately wide, but I wouldn't call it an actual wide angle.Nice discussion.
So, the 20mm 1.7 would be consider a nice wide angle option, acording to film standards, in a m4/3 chip?
thanks.
I think a 20 would be fine as a kind of "medium-wide". As dop16mm said, though, for a true "wide" I would consider something around 15mm.
Yes, look for any "Nikon G" adapter for m4/3. Rainbowimaging makes one. They're cheap, but they're manual control, so ... for a budget they're available now. I don't know if it actually lets you set the f-stop you want, or if it just closes the iris down and you decide that the image looks good at that point? Haven't used one.Is there an adapter currently on the market that can control the aperture?
No. I have one of those and it doesn't letyou control the iris.Does the Voigtlander VM Micro 4/3 Adapter let the camera body set the f-stop because I don't see an aperture ring on the lens.
There's no rush, the AF100 is still two months away, so def. wait and see what Birger (or any other manufacturer!) does. But if worse comes to worst, yes, there's a solution on the market today that would let you use the Tokina (or any aperture-ring-less lens) on the AF100 right now.Perhaps it would be smarter to wait and see how the Birger mount looks.
Exactly agreed. For a true wide, the 14mm f/2.5 looks like the lens to consider.
If you've ever seen the film, these wide angle lenses do stick out almost every scene and add a 'strange' aesthetic to the story and visuals....For the balance of the film, however, Pecorini shot with Zeiss Standard Speed prime lenses. ...In terms of specific lens choices, Pecorini indulged Gilliam's preference for wide angles through-out the shoot. "I'd say that we shot 95 percent of the film with 10mm, 12mm or 14mm lenses; that was our primary range! Sometimes I would check the shot and say, 'This is 16mm,' and Terry would look at me and joke, 'Are you nuts? That's telephoto!' We were sometimes literally shooting with a 12mm lens three inches away from Johnny Depp's nose."
- Nicola Pecorini
Wow I earned a sticky, cool, you guys made my dayIf only I could put down a pre-order to prove my theories come New Years. Alas feed the kids and house payments come first. If all goes well a project will be financed by summer and one will be coming home.
$20 says using the 20mm will be wide enough for you.I personally need wider than 20mm for
- Videoclip
- Documentary
- Verry small place run and gun, when you cant just frame everything you need whit a 35mm
- Special shot
- Inside cars
- Extreme sports
So i need to have this option right in my bag. Now i just dont know what to pick up.
- Panasonic Lumix G Vario 7-14mm f/4.0 ( dam its slow but dam its wide ! )
Since i want to shoot street shot at night in busy city street ( Spoiler, like in japan ) you think that whit the the correct AF100 iso set-up whit this f4 lens i can put something up ?
Because we can see how it perfrom in day in this philip bloom test http://vimeo.com/16129196
But what about night ? at f4 ....
Maybe the elevator at 0.26 ?
But, that being said, a nikon adapter and the token 11-16mm f2.8 is just the ticket you want.
Lol. Sorry that was the tokina 11-16mm. Stupid text correction.And of course there is no x1,9 factor ? Like its not a 22-32mm on the AF100 ...
