Do remember that these filters use polarizing glass, which also effects your image, eliminating any reflections depending on the angle (When 'fading', the polarizing effect might change as well). It might not always be what you want.
this is one of the side effects of not using nd filter to get the fps closer to the 100's and down, Im I correct?
Again, I'll throw my support behind the Vari-ND from Singh-Ray. 2-8 stops of ND, easily controlled by turning the front element. Expensive but worth it.
--SM
I am using the kit lens with the Vari-ND.
I've got the 77mm size, and I'm using it with a simple 62mm to 77mm step-up ring. (I've also got a 52mm to 77mm step-up so i can use the Vari-ND with my Olympus 50mm f2.0 Macro lens.
Another benefit of this is that I'm not buying any 62mm filters. I can use the same 77mm filters I use on my EX1 with the GH1.
--SM
