When I switch my DVX100A to AWB Preset and then click the AWB button, "AWB" pops up in the center of the screen. Should I be seeing it cycle from 3200 to 5600? If so, what may I be doing wrong since I can't get it to cycle.
in the menu you can setup one of the presets to auto white a,b or the preset usally the preset is already set up to do it and the a and b are done manually so when you see awb that means its doing it automatically and you should manually w/b on a or b. it helps so when you do run and gun going from indoor to outdoor and dont have time to stop and shoot white just flip from a or b to the preset and it does it automatically.
There's two presets in the auto, 3200 and 5600... so yes, you should be seeing that.
If you're trying to manual white balance (which it sounds like you are), switch it to manual, fill your viewfinder with a white card (or anything completely white), and press the white balance button on the front of the camera.
also READ BARRY'S BOOK. All this stuff is explained, and it'll get you going 100 time's faster than attempting to figure it out by trial and error (and save us from having to answer a bunch of commonly asked questions).
