morgan_moore
Major Contributor
OK how do you control WB on this little thing?
What I reckon is happening..
Preset - uses the temp you have set in the menu
A - goes to an unkown to me value
B goes to an unknown to me value
apparently the same
Pres the WB button and it samples what you are pointing at
Once the WB button is pressed the switches do nothing
If the camera holds this value with removal of battery etc I dont know
Also Im not finding the 'Drifting WB faciliy' which while generally avoided could be of use for example transitioning from a Daylight EXT to a Tung room
I have Flouro and Tungsten lights and gelled T too
I would like to point one of these at a white wall (lit with Tung source) and press WB to sample it - I would then like to save that as 'my tungsten'
and repeat with 'my flouro'
And Shade and Sun ?
Maybe Id then like to tweek the sampled settings to create my own feels like 'Flouro Warm look' or "cold under tungsten"
What is the approach people are taking
One thing I want to be able to do (especially in my studio) is get consistency between Monday and Thursday - even if I shot something else on Tuesday in a different locaton
Currently the only one of value seems to be a setting in the menu - but thats a bit clunky and would need notes if shooting over days also it is a complex rejig in the menu to compensate for flouro which might be a bit green and needs a magent swing and that cannot be done on the temp scale - but in the PP menu
TIA
S
apparently the same
And Shade and Sun ?
TIA
S
