harrisoncj
My favorite card is my 16 gig Hoodman RawSteel class 10 card. It's metal plated, so breaking it is one less thing I have to worry about.
CARD ERROR!
Hi I'm hoping this is the right place to post:
I'm using two 32gig kingston 100x ultimate cards. While I've never had any problems while recording, i very often get this message: "Inconsistencies found in the image database file. Back up and recover." etc. ..
It gives me the option to recover by pressing OK - or to Cancel. I always do the latter, then turn of the cam, back up to a computer, stick it back in and do a format in the camera, and im running again. It never resulted in any actual lost data - everything was always there when I connect to a computer.
BUT as said, it happens quite often, and makes my heart jump a bit every time (!)- and of course it implies the hassle of having to bring a laptop everywhere. It always happens when it has been powered off btw, never when I just leave it on.
Any takes on what causes this? Is it my cards, my particular camera or is it a common thing??
All help is greatly appreciated!
I always fill each card about half way as well. I find that especially with my CF cards, performance dwindles towards the end of the card's capacity so I always keep a bit of a size buffer there. So for a 32gb card I'm usually using about 16-20gbs.
I'm curious how you test this perceived loss of performance...It's amazing how much crazy "voodoo" there is out there. This is one of the silliest things I've ever heard.
Regarding 8GB cards, they are unusable for any long form recording (concerts, weddings, etc etc). I usually use 32GB cards and, starting next year, will be using an AC130/160 so it will be recording to 2 cards at once.
I'm suprised I never see anyone using the "Sony Memory Stick Pro-HG Duo"? I bought a 32G when I got my FS100. It's cheaper than a SD 32G with the same speed. I haven't had any problems with mine. Does anyone know of any problems with the Memory Sticks?
It's common in regular hard-drives, the more full they get, the slower the data rate. You can find that out by using benchmarking software like hdtach. I'm probably totally off but I just figured it would be the same with SD and CF cards.
Plus when I was shooting with a 7d, towards the end of the card, i'd get more clips that would stop recording early. I figured it was something to do with the card nearing its capacity.
It's common in regular hard-drives, the more full they get, the slower the data rate... I'm probably totally off but I just figured it would be the same with SD and CF cards.
It's worse... much worse. Flash memory is REALLY nasty to work with... most cards can only physically write a block of 4MB or 8MB at a time. Yes, that's MEGABYTES.
The controller (the one built into the card) tries to mask this by clever use of cacheing in RAM (also built into the card). How good a job it does depends on how much RAM it has, and how sophisticated the controller is.
