One consideration about formatting, is that footage isn't the only thing that might be on your card. You might also have metadata files or scene files. If you format, you'll be erasing those as well as the footage.
If you use scene files or metadata files, it's good practice with the AVCCAM cameras to use "delete clips" instead of formatting.
So scene files are not stored in the camera itself? They are stored in the sd card that you happen to be using when you set your scene files? Could you please elaborate on your quote. Thanks.
