Tracey Lee
I left those unchecked and I am still getting pretty amazing avchd footage. Just thought I would ask in case they make a difference. Thanks!
Does setting them lower than stock settings make for less compression/better image?
Depends on what you mean by "banding". If you mean 8-bit dithering, that's already been helped a lot by a bigger bitrate, and as Kholi says, juicing the NR down and upping the ISO to 320 will take care of just about any banding that remains.Could lowering the GOP setting help reduce banding? Or is that caused by something else like the 4:2:0 color space?
If you mean the vertical streaking, that's a sensor issue that would have nothing to do with the codec.
4:2:0 shouldn't be a factor in the banding. 4:2:0 still has an 8-bit bit-depth, just like 4:2:2.
Counter-intuitively, it may be that shooting at a higher ISO improves overall image quality
in some cases by introducing enough noise to minimize the apparent banding.
But shooting with MJPEG is the only thing I've found that delivers these shots with no banding.
I shot stuff last night with a GOP of 4. But as soon as I went outside this morning to shoot high detailed trees and bush + sky it froze every time it went to 5 seconds. I'm just sticking with the 50 52 60 24pn setting for now.
It's frustrating, that's for sure.. So your sticking with gop15-"C" settings and 24PN?
I have tested AVCHD 1080p/24fps and 720p/30fps with GOP's as short as 12, and have seen no recording or playback problems. When I tried setting the GOP below 12, however, the camera froze each time I hit the record button.
"C" settings+ 1080P/24PN + 12GOP + Star Chart = Write error....
I think there is indeed a formula to them all and changing a few things can/will change the way other routines are run as well, thus the reason we have so many different problems even though we only change a few different things.
