What's in a thumbscrew? A lot actually. A Redrock review.
yoclay
I recently received the new Lift-n-Lock thumbscrews from RedrockMicro as well as some of their newer Microhandles, and for something so small the difference is profound.
I make no secret of the fact that I found the previous thumbscrews to be a frustrating experience. Having to always carry a hex key with me (and thus constantly losing it or even several in the course of often chaotic professional circumstances - assistants love to keep things) was becoming a real pain. Tightening things down like all heck and finding the two thumbscrew elements constantly seperating from each other because they in fact tighten in opposition to each other, I often had slippage on some of my components like the Redrock Microhandles and other key pressure points. Then occasionally too a thumbscrew would pop in the course of tightening because there were not enough threads engaged and the fear that would form in the eyes of my AC's was a beautful thing to behold. It always gave me the opportunity to treat them charitably and reassure them that nothing was broken. I found too, that often since the knobs were coming up against each other when combining pieces, I needed to calculate the optimal way to tighten them down before they blocked each other's paths. This resulted in a special kind of dance when pre-configuring rigs which was a bit like trying to predict an uncertain future on the deck of a warship actively engaged in battle. "God no, not a new setup in the middle of shooting!"
Turns out I was doing things a bit wrong.
Speaking with Brian Valente of RedrockMicro recently about all of this I learned a lot.
First off Brian is a great guy. Courageously ahead of the game by at least a full year regarding the DSLR revolution, he and RedrockMicro remind me of something I have long felt - that good entrepreneurs are a lot like artists, they need to be able to take risks, think creatively and have a strong vision in order to succeed. Additionally, I have often seen Brian do superbly in one place where artist's don't often fare quite as well. In the face of withering criticism. On a couple of forums recently I have seen some incredibly rude behavior towards him (especially about the recent price increases), and he always responds gracefully, with an eye to learning something but also treating others with respect - even when it is obvious to everyone, including myself that these unpleasant assailants have been eating a few too many Fruity Pebbles for far too long. Additionally, Brian was very careful to stress that RedrockMicro is a team effort and that while he is the most visible face of the company, there are a lot of other individuals behind who have an important hand in the decision making process.
Ok, so getting back to basics, here is what the old thumbscrews look like:
file.php
Thumbscrews 1.jpg (93.01 KiB) Viewed 168 times
As you can see the blue metal piece operates independently of the actual hex screw. Why? Very simply put Redrock wanted to allow you to be able to choose the color you wanted for the detailing. I believe at the onset the choices were blue, red and black.
file.php
Thumbscrew 3.jpg (111.71 KiB) Viewed 166 times
This meant of course that the actual thumb pieces could be pimped out with the rest of your rig, which is no small thing when you consider that some rigs may have upwards of 15-20 of them. Lest you think this a terribly west coast Hot Rod phenomenon (I believe there is even a camoflage -" special ops" look available now) the truth is likely that Redrock's brand identity is definitely connected to that blue black color scheme, making it instantly identifiably to rig geeks everywhere. However some folks might have a preference for instance for a more sober all black rig. Having come of age in the 80's I certainly appreciate that. So part of the reasoning for these cosmetic alternatives may also have been to be able to pimp" down" rather than "up" your rig. This is indeed In contrast with a brand like Zacuto, which always let's you know it is coming because it is screaming red and black "Z" thingy's everywhere. Good brand identity for them, not so great in situations where discretion is needed for you.
The problem was that screwing the thumbpiece up the post in order to align it, is going in exactly the opposite direction as when you tighten down the whole piece, so frequently the two would become seperated like this:
file.php
Thumbscrew 2.jpg (119.62 KiB) Viewed 166 times
Brian provided some answers which also give us some insight into the problems.
He said actually the design of the thumbscrews does not differ that much from other manufacturer's, except those products are fused. His goal was actually to give greater flexibility and choice as with the handgrips, but the reality they learned is that the number one issue people had was that the thumbscrews indeed became unthreaded. On most pieces like their micromounts, it never has been an issue, but on some of the larger more visible pieces it has been a concern. He also said that their is a simple solution, if you don't mind losing the flexibility of the two seperate pieces and that is:
file.php
Thumbscrew 4 (loctite).jpg (102.4 KiB) Viewed 166 times
You simply put a drop near the head of the screw and tighten down. It will become fused, however you will lose the flexibility of two pieces in certain situations.
The other hidden advantage of having two seperate pieces may have been (at least in theory) that in a tight space on the rig with two thumbscrews close to each other, loosening the thumbpiece and then tightening the center bolt down with an Allen wrench as an alternative was sometimes the only other way to turn the knob. This occasionally led of course to overtightening and a lot of effort as to calculating the right amount of extra play to give things. Hmmm if I go here, and do this one and then that one, in order to tighten perfectly within the limited radius left on two adjoining pieces...hmm maybe I'll go have a sandwich instead. Not only could this become a rather tedious and time consuming exercise, but also a potential source of hairloss, especially with a number of rigs constantly circulating on a hot set.
Here is an example of an abuttment like the ones I am speaking about:
file.php
Thumbscrew 5.jpg (135.95 KiB) Viewed 166 times
The obvious question is one of hindsight. (Hindsight being 100% perfect) Why not offset the screws in potential abutting areas so that they don't conflict? (I am not sure that structurally this might have been optimal for applying equal pressure in the right places, but one could imagine it as a solution).
The first thing Brian said is that at the time no one at Redrock actually considered how many potential variations people were going to come up with to put these these rigs together and that it has become even clearer over time that the real philosophy was still to give people a set of pieces with multiple uses and possibilities. It has also become apparent that there is a movement towards smaller, lighter rigs (many female users actually prefer these rigs). This is why the Nano rigs were created and have become so important, not only in terms of ease of use and simplicity, but also price point. Which has created a different set of technical needs and requirements. Further, this kind of evolution is not something they would have predicted and one of the hidden consequences is that there is even less room for space between the knobs than on the larger more "cinema" style rigs. So practically speaking there is often not even enough real estate to create an offset thumbscrew system. So much for my feeble attempts at being a master designer.
Which is where the Lock-n-Lift thumbscrews come in. Rather than redesigning old pieces and thus creating potential conflicts where people would have a REAL problems with compatibility, this new thumbscrew provides a very elegant solution which even works with old pieces going forward.
It is apparently something that no one else offers and much expensive to produce than people might believe, (which was the primary source of price increases earlier this year on many products). As a stand alone product according to Redrock, it will still be cheaper than inferior replacement knobs being offered elsewhere on some other manufacturer's websites. They has so much confidence in this little piece that I believe it may even be patented. These new knobs have been shipping since earlier this year and anyone who orders any of their pieces now will get them automatically. For those who already own Redrock pieces, they can upgrade just the pieces they want on an item per item basis. This means that practically speaking in the field, the speed with which a new rig can be put together more than doubles (in my experience).
So for a very small product it plays a very big role in the evolution of their products going forward and ease of use for the enduser.
file.php
Thumbscrew 9 (Lift-n-Lock).jpg (101.74 KiB) Viewed 167 times
In the case of abutting screws like the ones I showed previously not only is it convenient to lift these new knobs up and over the other screw in order to keep tightening, but I have found that virtually no pressure is needed to tighten anything down now. No strain or over-tightening required at all. A godsend!
So my recommendation would be that on most pieces which are stand-alone like the thumbscrews on the Redrock shoulder mount....
file.php
Thumbscrew 6 (shoulder mount).jpg (105.65 KiB) Viewed 167 times
.....you can go with the loctite solution and on the pieces like the support arms which are in my illustration above (Thumbscrew 5.jpg) or pieces which are often grouped closely together and difficult to access (for instance on the underside of a rig near the front), the Lift-n-Lock knobs are really a good alternative. That is of course if you have not already purchased the newer versions of these items which already have these later knobs integrated.
Speaking further with Brian we talked about how the solutions needed for RedrockMicro, have to hit a certain sweetspot. There are easy solutions to all the technical problems out there he said, but they are meaningless if a DSLR customer cannot afford them. Further he said, "it's easy to build what one person wants, it's much more difficult to make something which works for many other people."
Ahh, this is part of the artistry of being an entrepeneurial startup company (though they have been around for a while now) and it's tricky. You sure have to be clever in my opinion to be creative in this arena, and not lose your shirt either.
This used to be an industry where a mattebox might cost $5000 - $10000 and no one would bat an eyelash, because the production budget might be in the millions. We all love that high end Arri gear made for Hollywood, but when you need to buy a third stage for your mattebox and the only way to do it, is to remove your 2 stage piece and spend another $2000 for a three stage one, we understand and appreciate why Redrock decided to create a mattebox which you can be build stage by stage.
I have noted that there are now many manufacturer's out there who have begun to provide cheap alternatives often based around designs which Redrock created (imitation is the greatest form of flattery), but often the tolerances of these products is nowhere up to pro standards. They are often built for one purpose and one purpose only, but could not function in a system like Redrock's where the enduser is putting them through permutations they were never designed for. The stresses are often too great and they will break easily along these alternative fault lines. So the challenge is to create something that is really robust but not at a price point like the products which have been typically coming out of Germany and Austria for years in the Cinema industry.
How then to make something cost effective then, but really, really strong with higher tolerances?
An example within Redrock of upgrading towards these higher tolerances are their new handgrips, the Redrock Microhandles.
Here are the old ones, and here are the new ones:
file.php
Thumbscrew 7 (Microhandle comparison).jpg (136.35 KiB) Viewed 167 times
So what is different between these two? Why would the one with larger surface area around the rod be less efficient than the other? The reason is tolerances.
Tolerances are a result of processes. Many products, like carbon fiber are made by injection molding, just like plastics. A mold is made and a liquid is poured in which will solidify. This is a process which can have fairly decent tolerances and is in actuality quite inexpensive from a production point of view. Many, many of the new rig companies out there are working this way. However, when you want to have very precise measurements to within .0001 of an inch, and for it to be supremely strong, machined metal is the only way to go, and guess what? It costs a lot more.
So what you are paying for in a higher performing piece like the metal handgrip on the right is a much more expensive process, made to exact industry standards. The difficulty is that what you are paying more for sometimes is actually not visible to the eye. If you have ever wondered why the rods from one manufacturer do not fit in the rod grips of another, it is because someone's work is not within industry tolerances. A 15mm rod is 15mm right? Not always and not exactly!
In any case their new grips just simply hold a lot better.
file.php
Thumbscrew 8 (Microhandles+black detail).jpg (112.74 KiB) Viewed 167 times
The move towards even tighter tolerances is the way Redrock appear to be going. I applaud them for that. That is an investment for the future. Not only for the manufacturer, but also for the buyer.
Not only does this mean that the quality is going up, but it also means that you have a product which is completely interchangeable with other manufacturers who care about meeting higher level industry standards. Inter-operability not only within RedrockMicro's line of products, but also outside of it. Which is more than I can say for a few other manufacturer's out there recently.
Lastly, at one point Brian said he didn't like to disparage other competitor's, because he felt that the client should be free to arrive at his own opinions and make his own choices. That is practically my definition of a class act.
As the fictional Ann Lander's once said (yes, even she was sadly a mere fabrication of clever entrepeneurs and the yellow press):
"Class never tries to build itself up by tearing others down. Class is already up and need not strive to look better by making others look worse.
Class can "walk with kings and keep its virtue and talk with crowds and keep the common touch." Everyone is comfortable with the person who has class because he is comfortable with himself."
Respect where respect is due.
Thanks Brian.
Since DSLRs people have forgotten how to build rigs (and I hang out with some professional grip people on occasion)
They Typical U clamp is a great solution for stopping a compeonent slipping along a rail, but no good for stopping an item spinning around a rail
When one wants something to avoid torque a U clamp is not the correct solution
joints that cope with torque are either serrated plates
see your tripod pan bar, or a ronford baker or element technica handheld rig
or by attaching something to two rails you eliminate torque loading too
(think about the difference between a regular FF and an M1 motor)
The regular FF stays in place because it is attached to two rails and stopped slipping with minimal clamping force
Had redrock not forgotten simple structural engineering they would not have come out with dumb designs like the handles attached to a single rod with nothing to stop them turning but the clamping forces of the thumbscrew, which is not only providing the clamping force but also needs to provide the force to bend the Uclamp too
In the case well structured rigs the initial thumbscrew design was perfectly adequate
An expectation for thumbscrews to work at all against torque is a non starter
Barking up this dead end has made the rig makers up their tolerances, with increased costs that they must pass on to their users, and a reduced probability of fit between parts
Even early RR handle bars were designed properly (ones that went under 35adapter rigs)
Generally I hate thumbscrews apart from the lowest torque environments, like a component to hold a Lav to a pair of rails
not only are thumbscrew mis used on rigs they take up a lot of space, if you need to turn them through 360 (which you will unless you pretension with an allen wrench making them rudundant anyway)
and offer little clamping force because they are so short
often rigs are designed so thumbscrews clash with other components (as you showed)
to design a rig with full clearance of the 360 of thumbscrews wastes a lot of space adds mass and provides poor clpming force for the space occupied
Real men use kipp levers and triangulate their rigs
EDIT. Ive just seen the new ones are lock and lift - that is a kipp lever, a nice small one, no doubt a major step forward for RR but still a U clamp is not an appropriate solution for taking torque like on those handles
ps you mention
"the enduser is putting them through permutations they were never designed for"
that is one thing Brian has had to fight - end users with no idea how to build a rig, gripping is a profession and art, yet end users jump on kit and then blame the maker when a singe rod slips with a 10lb wight hagning off it, forcing the maker to up their tolerances and costs
I wont even start on tolerances, engineers that rely on tight tolerances to do simple jobs are poor engineers - this stuff is all so wrong its a joke :)
Gee, so they are actually delivering Black Set screws now? It was an ordering option that was offered when I bought their very first HDSLR rig back in January 2009. even though I ordered black trim, I got the ugly, and playskool looking blue setup. Writing and calling did nothing to get them replaced. I sold this crap on ebay and managed to recoup my sizeable investment on basically unusable and clunky first generation junk.
Good to see they are finally making good on the promise of a color choice made back in 2008/2009.
This is an awesome forum, for starters... This will be my first of probably many posts, I hope!
I have been searching EVERYWHERE for these "thumbscrews", but cannot find them! I want to buy them, preferably without the allen cap screws. Can you PLEASE guide me in the right direction?!
I have Googled until my eyes began bleeding (seriously, blood-red!) and I cannot even figure out a name for these things! Just when I think I've stumbled upon something, it turns out the item is just way too big!
I've been in contact with Cine City (PROAIM people?) and some others, but to no avail.
Can anyone help me locate these thumb screws/thumbscrews/handles/knobs/levers/locks/QR/quick release/swing clamps/hook clamps?!? And preferably without the RedRock emblem emblazoned on them.
Many thanks!
Haha... I found myself here after googling for some of these "lift-n-lock" type of thumb screws also. I'd love to find a place that sells them, but I'm really not sure about it's usage outside of the film world. I'm sure there must be something, though.
Also I know this thread is old, but I'm going to throw a couple comments in. I agree with Morgan on the grips. Those redrock grips are trash, as is a lot of redrock crap in general. I appreciate their apparent caring for quality, but I honestly think Redrock is a company born out of people who never REALLY worked with professional gear on a regular basis. It appears to me that they probably saw a real follow focus a few times, spun it back and forth a bit and thought "hmm... this isn't so hard to make... Lets make money with this in the low budget world!" The problem I have with it is that it's not exactly low budget for the quality level that it is. :P
Well...granted a redrock follow focus at least locks securely to the rods... That's more than I can say about Arri's more recent handheld FF..
Anyway, I'm a union camera assistant in LA, and on occasion I'm forced to work with Redrock gear...more often than not, in a situation that involves a personal camera package foregoing a rental house. I cant really say that I care for any of it. It's ALWAYS a frustrating experience, and certainly those thumbscrews have bugged me forever. But Arri has had those "lift-n-lock" style since the 80's! Why this re-invention of the wheel for all of their products? It seems like they just didn't really pay attention to the matte-boxes, follow focuses, and *gasp* "lift-n-lock" thumbscrews that have been in pretty solid design for decades. If they did, they'd probably have much better gear, without having to learn how to fix all of these problems that Arri and Panavision fixed years ago.
Redrock, you confuse me...
P.S. Ah! Kipp.com! I read the comment about the Kipp lever earlier and immediately found the bike-wheel style cam levers. Took me a while to come full circle and find Kipp again. heh. This is everything I was looking for! Awesome...now to see if a local distributor will let me just order 10 or so :P Thanks Morgan.
MattyKrab,
On the contrary, Redrock actually started from filmmakers. Redrock started with their 35mm adapter, and then later moved into support gear. Their new Follow Focus Blue is incredibly solid, and I have yet to have any issues with their new handgrips slipping like the very old ones did. Admittedly I noticed a fair amount of trial and error in some of their early product designs, like the original handgrips, but I think their new stuff is really top notch. I don't only sell Redrock stuff, I use it on my personal rig as well. If you're in LA I'd suggest visiting them tomorrow at the CineGear expo down at the Paramount Lot. As an AC you might even take a shinning to their new 16 channel remote follow focus system and sonar range finder. My name is Loren and I'll be down there with them, so feel free to ask me for a personal demo and stress tests :)
http://store.redrockmicro.com/AboutUs
Redrock background ..avid digital filmmakers whose desire to produce high quality movie images without access to huge budgets ..
Today, Redrock Micro designs and sells a line of high quality cinema accessories for independent filmmakers, film educators and students, and budget-conscious moviemakers
Thats completely different from union set style experience
All the great handles use a the serrated plate design , Ronford, Element Tech etc..
