I have some cheap 16mm aluminium pipes and I was wondering whether the holes in the brackets used in 15mm rail systems usually about 16mm or greater then tightened to 15mm less to secure the 15mm rails.
I want to see if I can use these 16mm pipes instead and build a shoulder rig or cage whilst using accessories for a 15mm system.
Does someone know what are the usual hole size manufacturers use for 15mm rail systems?
