Viddovation
My point was more that Cine-EI give you a number it calls EI200/ISO2000. It doesn't matter if that number is accurate because it can't be changed and one has all the tools and readings to expose accurately for that number and in addition can calibrate a light meter (shock, horror!) to be accurate to that specific camera too.
I mean, that's true, but it's also nonsense. Yes, in CINE-EI the signal is recorded at the "native" EI2000, and you can't change the level the signal is recorded at. However, you have "all the tools and readings to expose accurately... [and] ...can calibrate a light meter (shock, horror!) to be accurate" at any CINE-EI reading the camera offers. Yes, this does mean you're asking your post software to perform a transform (shock, horror!), but we do that *all the time!*
If baking the exact image we wanted as our final output into the original recording was a paramount requirement, we would all be using custom mode color profiles, not S-Log and CINE-EI. Both you and Doug Jensen seem to propose that CINE-EI transforms are to be avoided if possible due to not making optimal use of the recorded image. But that was really a significant factor, we wouldn't be getting beautiful rich saturated images from S-Log in the first place, since that also is (shock, horror!) a transform away from the recorded S-Log curve.
