Right now I capture in Premiere Pro 2.0, as DV (with DV lock turned on). Do I need pulldown removal still?
Also! Does DV Lock cause a lot of quality loss? I couldn't figure out how to capture in Premiere with DV Lock off, so I turned it on and it works now... has anyone had success with capturing in Premiere Pro 2.0 as HDV, od should I use the HDVSplit?
PS - I tried using HDVSplit and can't get it to detect the HV20 (even after I turn DVLock back off) - so if that's the way I should go, I'll need to get back in troubleshoot mode.
PPS - I edit on my laptop, and its harddrive is a mere ~100 gigs. So HD won't be easy - can I capture directly to an external with USB 2.0 and edit that way too, or is that dangerous/way too slow?
Thanks!
Thanks!
