What he best way to make a 720p dvd for projeted use?
Green Hornet
I have a projector which I believe to be 720p capable.
What would be the best way to create a file to be projected in this format.
1) what dvd player?
2) what file method?
Can you edit a file, then put it back onto a p2 card for playback? If so, how would one do that?
What kind of inputs does the projector support? You'll need a DVD player that supports that input, as well as some form of high-definition format such as DivX Home Theatre or WMV-HD. Frankly, there aren't a whole lot of them.
Whether you can output back to a P2 card depends on the editor you use. Canopus Edius Broadcast 4 supports this, it will even split the output if it doesn't fit on a single P2 card.
