what does this mean?
KSommer
Audio only capture selected video disabled ? When capturing from DVX to Final cut express?
I've downloaded video fine the first three times, no problem and now this comes up. I don't recall ever switching anything.
It loads the audio by no video, even though I'm seeing the video in the capture now window.
ODD! Please help I'm surely just missing something simple.
Thanks.
Kevin
In Log and Capture, click on Clip Settings. It should be the tab right next to Logging. It seems like you've deselected Video. Select Video and everything should be working fine.
The manual has big section on this.
Take a look at it, or check the pdf manual on your install discs so you can do a search for the issue.
Report back
Thanks. I got it figured out through Apple, the part about how to reset the program. Didn't really know how I de slected the video though, so thanks for your help on that.
For me just starting out I was simply using this "
1. dump video to through the capture window laying the whole video down and not by clip.
2. Going through the video and setting in and out points than to time line.
I have yet to use the file and transfer section you sent me to. Seems like an easier way for individual clips.
Thanks.
