morgan_moore
Major Contributor
If we consider a monitor as a set of 'variable power lightbulbs' where input voltage leads to brightness increase, in an array (lightbulb =pixel rgb pixel??) with some sort of digitial interface to translate input digital value to voltage then..
An expensive monitor may convert volts into more nits than a cheap one but for a single monitor..
709 : Input signal of 255-255-255 applies full voltage to the lightbulb and the monitor goes as bright as it can.
HDR : Input signal of 1024-1024-1024 (?) applies full voltage to the light bulb and the monitor goes as bright as it can
Difference to viewer.. none.
Clearly a monitor that is expecting 1024 to mean 'full bright' receiving a signal of 255 will not show full bright.
However a simple mathmatical transform can translate 255 to 1024.
Clearly 1024 levels allows more precision between 0 and 1025 compared to 0 and 255, but we all grade in 32bit float anyway, but most of our monitors dont really show us that.
Maybe HDR ready cameras 'bake' at those HDR levels and talk in them.. but we dont bake around here!
S
S
