If your brand new DVX arrives with the Lens Cap off HOLD A FLASHLIGHT UP TO THE LENS AND CHECK FOR SCRATCHES!!! When my DVX arrived the lens Cap was off, so I assumed it could have bounced around in the box and hit the lens. Well, I assumed right, but, unfortunely due to my ignorance I did not use the correct procedure to inspect the lens. I simply held the camera up to available light and did not see anything wrong. However, this past Friday I was using the camera for the second time and looked at the lens as direct Sunlight was reflecting off the lens and to my Horror I saw tiny scratches. I knew I had not touched the lens and the only explanation had to be the loose lens Cap. If I would have known to hold a flashlight up to the lens I could have immediatly sent the camera back to B&HPhoto for a replacement, but since I received the camera in September B&H will not take it back or repair it. So for my fellow newbies, don't be as ingnorant as I was and HOLD A FLASHLIGHT OR SUNLIGHT UP TO THE LENS WHEN YOUR DVX ARRIVES!!!
