Thanks. As I wrote initially, I'm looking for loudness normalization, not only peaks or RMS.Most DAWs and sound editing apps have some kind of normalization process already. Sound Forge Pro for instance, has Peak and RMS normalize options.
Thanks, see my comment to Chris below.Otherwise. I recall folks liking the automatic "LS Levelator Free" However, the folks that use it likely are not audio pros, so you will have to try it for yo'self. This is a stand alone app BTW, not a plug-in.
+1 Yes definitely check out "The Levelator" I dismissed this out of hand originally until I had a nightmare of hostings where the show hosts, booming voice adults, were interviewing young child performers many of whom had tiny voices.
However, I'm not sure if only limiting the peaks will be good enough; it seems to me that the entire volume of the few loud parts should be taken down.
Your thoughts?
'Mixing' is what I had in mind as best approach to this particular recording. That is, manually lowering the level, or volume, of the occasional too-loud parts. That is what I intend doing.
However, I don't get what you mean by 'volume automation' or 'level automation'. It looks like a term I'm unfamiliar with. In my mind, manually adjusting the levels and 'level automation' are two different, even opposing things.
Jim:
I have and read the 'Dialogue Editing for Motion Pictures'.
iZotope plugins are too expansive for me, being an amateur, doing non-paid jobs.
