Thanks for the comparison. Skin looks better on the micro to me.
I think these tests will be more helpful if you go for accuracy rather than such extreme grades. Her white shirt is completely blue.
Well thats the thing i dont want to color grade the images because I believe that defeats the purpose because you will be hiding the true potential of the cameras. I will upload the post process i did so people can see that all i did was a rec 709 lut and tweaked her skintones a little bit. I could have done a million things to both images but thats the thing with vlog and raw you can tweak them to hell but to show non experienced colorist like me what the images look like with minor tweaks, i had to do the test like this. I am trying to upload the raw files but googledrive is being a witch.
I see dead people... zombies...
I think that using Natural profile and auto white balance the result would be much better than any of these grades.
This was graded in FCPX using Logarist with a bit of manual color board in between and after the Logarist set. Not perfect yet either but I spent about 30 seconds on it. The manual adjustments were the required color board average exposure adjustment Logarist uses. The color board at the end of the stack was a tiny color shift and I brought the lows down a bit more.
I like the greens from the Logarist grade, which gets rid of the yellow-green I often see in typical Panasonic footage.
Logarist still left her shirt a bit blue and if I spent more time I would tweak the color a bit more.
Didn't do the DNG files because much to my surprise FCPX doesn't support CinemaDNG. Lame. I have worked with RED footage in FCPX but this was my first time using BMD raw material in FCPX. Rather disappointed by that. Guess which cameras I will not be buying now.
