Someone recently did a transcode comparison test with 5 various applications. Do a quick search.
They both remove 24p pulldown. The quality of the Cineform conversion is vastly superior to the quality of the Voltaic conversion, in my testing. However, the Cineform file sizes are simply massive as compared to the Voltaic file sizes.
I've had the same issue as you, Pappas. The interlacing artifact doesn't happen on all shots, but I've seen it on more than a few.
I haven't seen any interlacing on NeoScene converted footage...
I am missing something in thinking that if we have FCP and Compressor we don't need either program in our workflow? I did buy Flamingo and VoltaicHD, but seem to prefer the FCP Log and Transfer to Compressor route in managing files...
What are the pros and cons?
This has always been an issue with all of Cineform's pulldown removal software. I think David Newman explained a while back that it takes that amount of time for the software to lock on. I think the idea is, when you shoot, to have some leeway in your footage so as to clip this portion off for editing.One issue with Cineform I've noticed; is in the first several ( between 0 and 10 ) frames there is an interlace artifact where the fields are not correct. Then it's fine, however what is causing this?
