Please read my original post again: with this new Rode VM HD, every HD SLR shooter can focus on getting great shots without having to deal with audio equipment to get quality audio (if you don't think this is pro-quality, that's fine. Just read on from here), thereby leaving the pro audio work to those pro sound guys who typically carry mixers, and/or use boom poles, and/or wear headphones, etc. You may be one of those rare people who are really good at both video and audio. Yet, generally speaking, it's harder to do a good job if you have to deal with both video and audio at the same time, than if you concentrate on either video or audio but not both. And Rode VM HD is a great way to let you focus on video.
Rode VM HD seems to be an all-in-one deal. If you give a HD SLR shooter such a mic (which is also a recorder) to replace either a built-in mic or a recording chain, how likely will he NOT be very pleased?
4) Now, the only question left unanswered is: how much will it cost to get such a wonderful convenience?
Don't hold your breath about it letting you capture "quality audio." It still doesn't address the main reason for poor quality recordings with mics on or in the camera, which is that 99.99% of the time, the camera position is the absolutely WRONG place to put a mic to record anything except ambiance. Even for closeup dialog, the camera position is going to be 3 or 4 times, usually more, farther away from talent than is the optimum working distance for even the best directional microphones recording his speech. In addition the axis of a mic at the camera will be pointed at the subject parallel to the lens axis, happily picking up all the background noises from activity behind the talent. There's no substitute for proper location and that usually puts the mic above and in front of the talent about 18 inches away from his mouth pointed down at an angle. Do the math ... consider a shot that's a CU of the talent speaking, as you might shoot in a location interview sequence. Camera is about 6 to 8 feet from the subject with a short telephoto setting so you render the image with the most pleasing perspective without distorting his facial features. Mic on the camera puts it is ALSO 6 to 8 feet from the subject, resulting in hollow, distant-sounding, noisy, low level audio. Doesn't matter if you're recording in the camera or with an external recorder - any deficiencys in the quality of the recorder and its preamps, or conversely any excellence they may have for that matter, will be completely masked by the poor quality of the sound picked up by the mic from attempting to record with the mic in that position in the first place .
good money from what i can tell as the father of a bride to beWandering around a wedding reception recording random comments is the only semi-legitimate use for either.
I assume you're talkikng about the VideoMic HD? If you output the audio into the camera as you shoot, the camera track will be in sync with the picture but the tracks recorded on the mic's built-in recorder will still need to be sync'ed in post. In that situation the camera track would be a scratch track used to aid in sync'ing the actual production tracks, then discarded.So when you input it into the DSLR, will it basically just sync for you instead of syncing in post? Are we expecting much better sound that Rode video mic pro?
so the track that is in the camera will not sound as good as the track from the sd card inside the VideoMic HD? So what then is the VideoMic HD outputting to the camera?I assume you're talkikng about the VideoMic HD? If you output the audio into the camera as you shoot, the camera track will be in sync with the picture but the tracks recorded on the mic's built-in recorder will still need to be sync'ed in post. In that situation the camera track would be a scratch track used to aid in sync'ing the actual production tracks, then discarded.
It would be outputting a copy of the same signal that is being recorded on the mic's SD card. I would expect that signal to be as good as what the mic itself is recording, the problem would be what subsequently happens to it as it passes through the camera's generally poor preamps and other audio circuits on its way to being recorded along with the video in the camera and with a DSLR there's no way to bypass those preamps.so the track that is in the camera will not sound as good as the track from the sd card inside the VideoMic HD? So what then is the VideoMic HD outputting to the camera?
