what is a bargain price for a 35mm LOMO?
Hello Together.
The lenses seem quite soft when wide open. They are sharp at 5.6
The PL mount adapter is from Ceico7
I dont't use a rig. Only the adapter and the lens mounted to it.
thanks!
i didn't quite got the lens support issue between the 18 and 19..
can you please explain it with some jpegs ?
I'm often curious as to why no one has tried to just use the square front anamorphic element in front of nikon or canon prime lens. You would have to build into a matte box to allow to for front element movement, but should work as well or better than projection adaptors like the kowa.
Thanks for all the info![]()
Here's a link to a photo of my Lomo Square Front mounted on 15mm rails in front of a vintage Konica Hexanon 35-100mm f2.8 zoom. What I'd really like to find is a Victorian tripod made of mahogany with polished brass fittings...I'm often curious as to why no one has tried to just use the square front anamorphic element in front of nikon or canon prime lens.
Personally, I like original Lomo creamy look![]()
