I haven't seen much of anything on the 7200… I always assumed it would be my next body, but man… talk about a ho-hum release.
Confused though - you want comparisons of the D7200 to the 5300, but you want to buy a 7000 or a 7100??
If you're looking for a 7000/7100 - do whatever you can to get the 7100. It was a huge step for Nikon in the APS-C semi-pro line. I've shot thousands of frames and hours of footage on both. Skip the 7000 and get another 5300 before you get a 7000. The 7100 is a much sharper and cleaner image for stills and video - it;s in the same class as the 5300 and they play well together.
The 7100 and 5300 are very similar as far as video goes - I've used both for 2-camera projects and they intercut just fine. The 5300 gives you 1080-60 and articulating screen; the 7100 is a more pro-level stills camera (but only does 720 @ 60fps). Dual card slots, quick white balancing, higher-end larger batteries, larger body. If you have HDMI monitoring gear, the 7100 is a great choice. If you need the rotating screen or do lots of conformed slowmo, get the 5300.
