Is it available at bhphotovideo yet?![]()
Outside of the refresh rate, the screen looks "normal", as if you where watching it in person. Seems like when I film a screen it turns a weird shade of blue and under saturates etc...
"LED Carpets" coming soon.
You have to make sure your lighting is the same color temperature of the LED screen. It may actually be higher than 5600k and typically is around 6500k. Thats the first part of the problem. If you want your subject to be the same color as what's on the screen it all needs to be 6500k or get a LED display that puts out 5600k if there is such a thing.
I'm going to assume that's part of the special sauce that makes these things so expensive. Shooting outside clearly cannot adjust the color temp of the sun so the LED displays likely can shift the color temp similar to how some LED lights can shift color temp. You could use very bright LED monitors as light sources but again that costs a ton to find displays that can get that bright. Thats the second part to the special sauce here. dimmable brightness and a range to match sunlight or very bright lighting. You try this outside in the summer in AZ with a LED from Bestbuy and you will likely not see squat on the display as you expose for your subject.
Thanks. I am thinking of when watching a channel like CNBC and the commentators are using the large looking TVs and they look great. I would not think the studio lighting would be at a crazy high kelvin number but they clearly have done something to get these sets to look good on camera. I am sure the cine screens are very specialized but these things look like normal TVs.
