Stephen Frost
... or, more precisely, it switches automatically to interlaced.
I have a 25P timeline consisting of progressive material recorded on a DVX100B (I live in PAL land). I want to create a MiniDV Master tape of the complete project. When I ask Sony Vegas (Pro 11) to "print to tape" I select "PAL DV Widescreen" (the material was shot in squeeze mode) and then when it starts to create prerendered files Vegas switches the project settings from progressive to interlaced. I can actually see it do this where the project parameters are displayed under the preview window. It successfully creates a bunch of prerendered files, as expected, but these are interlaced, so when I print to tape some segments are interlaced (the prerendered ones) and some are progressive (the sections that didn't need prerendering). Of course this is no good - not only do the interlaced segments look, um, interlaced, they also seem to cause some odd-looking pixelation on playback.
I have tried this on two different cameras - firstly a handycam, which I use for capture into Vegas, and secondly the DVX100B, just in case it was the camera at fault, but I get the same problem with both.
I have looked everywhere through the project preferences, but I can't find anything that might relate to this.
Anyone had the same problem and found a solution?
Many thanks for any help you can give me.
Stephen
Stephen
